Как менять подстаканник с крышкой с разбором центр. консоли
Добавлено: 30.04.2010 17:44
Как менять подстаканник с крышкой с разбором центральной консоли.
источник импортный http://volvospeed.com/Repair/s60_center_console.html
Your console accessory tray door broke off and you would like to replace it? However you cannot replace the door itself you must remove the console and replace the entire insert. This should help you remove the console and replace the insert tray.
Ой сломалось! Надо менять!
Start by removing your handbrake trim it just snaps out.
Снимаем панельку вокруг ручника. (очевидно вверх тянуть надо)
Next open the back half of the console. There is a trim panel on the bottom inside that also just snaps out, remove it and you will see 2 torx screws underneath. Remove both of the torx screws.
В соседнем ящике снимаем для манет держатель и то что под ним. 2 болта на фиг.
Now you must remove your lower trim panels on the console. Look at the bottom inside corner of each front seat and you will see a plastic trim fastner on each side. Rotate this a 1/2 turn releasing it from the console. Now slide the entire trim panel rearward releasing that from the console.
Пластассовый болт на пол оборота.
Move to the front of the console, carefully remove the small trim piece under the power point (cigarette lighter) and heater controls. Use a tiny flatblade screwdriver for this, it also just snaps in place. With that removed you will see 2 torx screws one on the left and one on the right, remove both.
панелька с держателем для пишущих ручек (карандашей и т.п.) отчелкивается подковывариванием
с левой и правой сторон чем то тонким (может лучше неметаллическим). Еще 2 болта на фиг.
Next is the trim piece covered in felt/fuzzies under the shift indicator plate. There is a screw at the back of the piece remove this and lift that piece out.
Пластмаску и уплотнитель на фиг.
Go to the back seat and lift the rear of the console upward, reach up underneath and unplug your rear power point(cigarette lighter) connector.
Разъем заднего прикуривателя отключить
The console is now ready to come out. Lift up on the rear making the console at about a 45degree angle from the floor and pull it slightly rearward. Now just lift it up and out of the vehicle.
Заднюю часть (та что ближе к багажнику) поддеть вверх на 45 градусов.
This is the new accessory tray waiting to be installed.
О-о-о-о! Нооовенькая! свеженькая!
Take the console to a clean area and turn it upside down. You will see the 4 torx screws holding it in place, remove them and lift the old tray out. Install the new tray and your ready for re-installation of the console.
Вверх ногами перевернуть консоль. Опа! 4 болта на фиг. Меняется на новенькое.
Reverse procedure to install and your new console tray with a door is now ready for use.
Вуаля! крышка новая, не то что раньше!
а что же делать тем у кого еще дышит крышка и сломан только один штырёк (ближе к водителю который) Как починить не разбирая консоль, и починится ли потом достать крышку, если всё таки разобрать консоль?
